location vats bypass module
Old May 11, 2009 | 04:00 PM
mike088's Avatar
I have a 95 camero with a 3.4 v6. I bought the bypass off ebay, but I dont know how to install it. can somebody help me plz thanks
Old May 11, 2009 | 05:58 PM
mike088's Avatar
Re: location vats bypass module
Can anyboy help me with this.
Old May 11, 2009 | 06:08 PM
BigBadLou's Avatar
Car: '91 Z28 convertible
Engine: TPI
Axle/Gears: 3.27 posi disc
I think you might be on the wrong website. This club specializes in the third generation of f-bodies, from 1982 to 1992.
I'd love to help you but I have little knowledge or electrical diagrams for the 93+ vehicles. If you can find the right diagrams, I can tell you what to connect where.
Lou
Old May 11, 2009 | 06:09 PM
tony_cogliandro's Avatar
Car: 1990
Axle/Gears: stock
never heard of one. vats is not in the mod its in the ecm.
the key has a resistor and a reader to see how much the resistance is.
the ecm has a program that goes out to see what the vat is - then it goes to the vat module which is located next to the fuse block. it asks - do we have a correct key?
the vats module looks and says yes or no.
I HAVE NO IDEA WHERE A NO VATS MODULE GOES.
run search for vats and there is a lot of info.
Old May 12, 2009 | 03:15 AM
FlyDoc's Avatar
Car: 92 RS
Engine: 94 LT1 383
Transmission: T56-6 Speed
Axle/Gears: posi, 3.26:1,
There is a bypass Module for the 4th gens. once it is installed it can only be used with one ecm it scans and stores the code for that car.
http://shbox.com/1/4th_gen_tech1.html
try this sight may be able to help.
Old May 12, 2009 | 04:02 PM
mike088's Avatar
Thanks flydoc that site did help.
Does anybody know what the fuel enable wire is on the vats connector
thanks
gta892000
Aug 11, 2019 11:16 AM
bbsr72
Sep 27, 2015 05:55 AM
sandman92084
Sep 12, 2015 10:27 PM
Jlanz55
Sep 6, 2015 02:35 PM
tonys91rs
Sep 2, 2015 07:07 PM
