Tail light fuse keeps blowin
Old May 18, 2009 | 01:45 AM
91project's Avatar
Car: 1991 Camaro RS
Engine: 305 c.i. T.B.I.
Transmission: TH700R4
Axle/Gears: stock open 2.72
Allright i replaced the fuse for the wire on the radio which provides constant power, then my dash lights went out, so i grab my test light and the only fuse thats bad is the tail light fuse, so i check my tail lights and there out, so i replace the fuse and as soon as i turn on the headlights it pops, does anyone know what else is on that circuit, and where the ground is for the tail lights?
Old May 18, 2009 | 05:21 AM
titan's Avatar
Car: 1990 Camaro RS
Engine: L03 305 TBI
Re: Tail light fuse keeps blowin
Mine was doing this too. In my case, where the harness comes out of the body, right behind the tail light, theres a vertical piece of (body) metal that the harness was resting on. Over time this had worn through the harness, and into the wires, grounding it out.
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
fasteddi
Sep 10, 2015 09:32 AM
Jetmeck
Sep 4, 2015 12:29 AM
90formulaVortec
Sep 3, 2015 09:26 AM
andy74
Sep 3, 2015 08:41 AM
