bad fuel pump?
Old May 18, 2009 | 07:04 PM
Frozer!!!'s Avatar
Car: '90 RS
Engine: Vortec 350
Axle/Gears: 3.23 non posi
bad fuel pump?
Im running a mallory pro comp fuel pump. It ran fine for a few days but the other day the fuse blew on it. Replaced the fuse and it still wont run. I checked the voltage across the pump and the voltage drops to 9 volts when I turn the pump on. When I disconnect the hot wire to the pump and measure the voltage I get 12 volts. I rechecke dthe fus eand it was fine after this. Does this sound like a bad pump?? All fuel lines and filters are new and not clogged anywhere.
Old May 19, 2009 | 11:08 AM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
FROZERN PUMP
It should be under warrantee.
Swap it.
Happy Racing!
If People Drove Any Slower They’d Be Going Backwards
Fog lights are not driving lights. Keep em turned off slow pokes.
How bout those dorks too scared to drive without headlights on in the daytime!
Old May 19, 2009 | 12:37 PM
Frozer!!!'s Avatar
Car: '90 RS
Engine: Vortec 350
Re: FROZERN PUMP
It an older one, I boguht it form another membe ron here a couple years ago. I just bought on on Summit todya and shipped it next day cause I need the car by saturday. I think the pump has been flaking out for awhile. I have the mallory 3 port return regulator and they say to adjust the fuel pressure to 5-7 psi with pump on but engine off. and I did that but when the engine is running the pressure would drop to 3-4 psi.
Glowsock
Jul 24, 2025 03:15 PM
mustangman65_79
Apr 14, 2017 05:37 PM
Bryan F
Aug 18, 2015 02:28 PM
Winchester1094
Aug 18, 2015 10:23 AM
Newguy91rs
Aug 7, 2015 09:51 PM
