ignition off, engine still running
Old May 20, 2009 | 07:25 PM
marine68's Avatar
Car: 89 IROC Z28
Engine: 5.7 L Edelbrock perf /holley 3310
Axle/Gears: BW 9 BOLT 3:27
i burned a red wire from the big post of the starter. the car did nothing with key in start run. i repaired the wire, now it starts, runs great but when you put the key in off, engines stays on, i have to disconnect the negative battery cable to turn off. i replaced the ignition switch, still not fixed. what could be the problem.
Fast355
Dec 2, 2016 06:33 PM
Caspar
Jun 19, 2016 11:19 PM
justin57
Aug 20, 2015 07:05 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
ZZ42Fast
Aug 10, 2015 08:20 PM
