neutral safety switch?
Old May 20, 2009 | 10:36 PM
red/white04's Avatar
Car: 88 IROC
Engine: 305TPI
does the TPI require use of a neutral safety switch...i'm in the middle of a TPI swap into a gbody and i got everything out of a 90 firebird...i wasn't sure if the computer pulled a signal from that or not
Old May 21, 2009 | 09:19 AM
BigBadLou's Avatar
Car: '91 Z28 convertible
Engine: TPI
Axle/Gears: 3.27 posi disc
Re: neutral safety switch?
If you have an automatic, the computer needs to know whether you're in gear or not.
Also, the shifter switch serves other purposes, like not letting the car start in gear and turning on the backup lights when in reverse.
Hope this helps.
Lou
Old May 21, 2009 | 07:41 PM
Car: 88 IROC
Engine: 305TPI
My monte neutral switch is on the column and it controls the back up lights and not starting in gear from there..just wasn't sure if anything actually went to the computer because it works just fine on a my carb setup.
MM2Robinson
Oct 1, 2017 09:16 AM
Veaceonee
Sep 29, 2016 08:15 PM
Stroopwafel
Sep 11, 2015 06:38 AM
Randomtask2
Sep 10, 2015 08:37 AM
Fronzizzle
Sep 8, 2015 12:10 PM
