Wiring up a light for closed loop
Old May 21, 2009 | 01:21 AM
Kevin84Z28's Avatar
Car: 1984 Camaro Z28
Engine: L69 305 H.O.
Is there a way to wire up an LED light so you can tell when the ECM goes closed loop?
Old May 22, 2009 | 11:49 PM
Kevin84Z28's Avatar
Re: Wiring up a light for closed loop
Bump
Old May 23, 2009 | 10:03 AM
BigBadLou's Avatar
Car: '91 Z28 convertible
Engine: TPI
Axle/Gears: 3.27 posi disc
I do not believe that the ECM has an output to indicate closed loop.
The only way would be to monitor the data stream on the ALDL connector and extrapolate the closed loop flag and turn on a light. You'd need at least a small microprocessor to do that.
Lou
Jae992
Aug 27, 2015 09:07 AM
stalkier
Aug 13, 2015 12:59 PM
tnrednneck
Aug 13, 2015 08:57 AM
Omega
Aug 10, 2015 12:46 PM
IROCThe5.7L
Aug 10, 2015 11:24 AM
