Why is this wire burning?
Old May 21, 2009 | 11:14 AM
amichals's Avatar
I just swapped in a 305 TPI motor in my originally 305 TBI camaro and now this wire burned up and the dash does not turn on when attempting to start. Can anyone help?Name:  Picture001.jpg
Old May 21, 2009 | 11:18 AM
amichals's Avatar
Re: Why is this wire burning?
This wire was also not connected. Im not sure where it goes but I know it needs to be plugged up.Name:  Picture003.jpg
Old May 22, 2009 | 01:41 PM
STRIKER911's Avatar
Car: 89 RS
Engine: 305 TBI (lo3)
Axle/Gears: Whatever is stock.
Is this wire on the drivers side? If so my car has the same wire unpluged. Could never tell where it went.
On your burning wire. U know its a short right. So its not a fuse although one could have burned up in the "meltdown". My advise may not be the best, but what I would do is see if the wire was loose at any junctions. If it was not then, find out where your grounds are for that circuit, & see if they are all making good contact, or just not hooked up. If all that fails then look at a tbi car, to see if that wire is a lower gauge (bigger wire).
Good luck. Oh and I wold not run power to it again till you go over the above steps. Some one else may have a short cut also. Anyone?
Old May 22, 2009 | 01:43 PM
STRIKER911's Avatar
Car: 89 RS
I see a lot of butt connectors. When you get the wire problem straight make sure you tape them up to keep water out.
eightsixseven
Dec 16, 2024 01:50 PM
GTAman
Mar 15, 2019 11:40 AM
Exxon Limited
Camaros Wanted
22
Dec 21, 2015 10:36 PM
Bryan F
Aug 18, 2015 02:28 PM
Exxon Limited
Aug 9, 2015 08:13 PM
