Wires melting when cranking motor
Old May 22, 2009 | 11:26 AM
Bo1226's Avatar
Car: 83 Z28 modified 350
I swapped out a fresh 350 in my 85 z28. If it starts right up no problems....if I have to crank for very long it burns up wires. Already replaced positive cable from battery to starter. Thought the positive cable was the prob. Thought maybe problem in starter...so I replaced, disconnected power to distributor and cranked for 5-10 sec. and didnt see any signs of probs. Car set for cpl months while replacing interior went to start it and battery was little low from sitting had to crank it and after about 3-4 sec of cranking wire coming off negative cable to ground body burnt. Any suggestions appreciated.
Old May 22, 2009 | 10:38 PM
afremont's Avatar
Car: 90 IROC
Engine: 5.7 TPI
Transmission: 4L60
Re: Wires melting when cranking motor
The small ground going to the body is not supposed to carry that much current. Make sure your fat negative cable is connected directly to the engine block.
eightsixseven
Dec 16, 2024 01:50 PM
Caspar
Jun 19, 2016 11:19 PM
mhatfield 14
Aug 15, 2015 10:47 AM
stalkier
Aug 13, 2015 12:59 PM
92projectcamaro
Aug 6, 2015 01:20 PM
