aux fan flick switch
Old May 25, 2009 | 12:51 PM
Canadianguy2006's Avatar
Car: 1990 Trans Am GTA
Engine: 350(5.7L)
Axle/Gears: 3.23 posi
if i wanted to hook up a manual aux fan switch where would i make the cut in for it? at the fan switch near the starter? and would the fan still come on at stock setting temperature if i spliced in a manual switch? (in case i forget to turn it on)
Old May 25, 2009 | 01:06 PM
lenzjj78's Avatar
Re: aux fan flick switch
I belive if you tap into the passenger side temp. sending unit and run your wire to the toggle and ground the otherside of the switch your stock relay will still work when it is supposed to and you will have a manual overide with the toggle switch
gta892000
Aug 11, 2019 11:16 AM
John in RI
Car Audio
Sep 10, 2015 11:24 PM
FormulasOnly
Sep 10, 2015 09:07 PM
64goatman
Sep 9, 2015 01:09 PM
85Special
Sep 3, 2015 04:21 PM
