HELP! Need to ID the wire
Old May 30, 2009 | 07:52 PM
Stonehenge's Avatar
Car: 1989 5.7 IROC Dark Red/Blk 92Z28
Engine: 5.7
Transmission: 700R
Can anyone help me figure out what this plug plugs into?? (see pic). It has green and white stripe wires going to it and another plug that stems from it plugs into the a/c compressor and it all goes to somewhere behind the firewall. My a/c doesn't work. I can't see anywhere nearby where it would plug into. HELP!
Old May 30, 2009 | 09:49 PM
GIJason91's Avatar
Car: 1991 Camaro RS
Engine: 5.7 350 TBI
Transmission: M5
Re: HELP! Need to ID the wire
well this may not help but i just re did all my wiring for my entire engine and i am no longer using that connector so its either for emissions or AC since i deleted all that garbage.
Old May 31, 2009 | 12:54 AM
Stonehenge's Avatar
Engine: 5.7
Transmission: 700R
Thanks for your reply. The smog pump has been removed from my car ( going to replace it soon ), just wondering where this connector connects to. The emissions parts are on the other side of the motor, but the a/c compressor is nearby.
Old May 31, 2009 | 04:15 AM
tom86iroc's Avatar
Car: 1986 iroc
Engine: alum. head 350 supercharged
Transmission: 6speed
Axle/Gears: ford 9in 3.90 35 spline moser axles
that connects to the back of your a/c compressor
Old May 31, 2009 | 09:33 AM
BigBadLou's Avatar
Car: '91 Z28 convertible
Engine: TPI
Axle/Gears: 3.27 posi disc
The flat connector (green/white and black wires) is for your A/C clutch and connects to the front of your compressor.
The round connector (green/white and blue/black) is for the high-pressure switch and goes on the back of the compressor.
If they were disconnected, it might have been for a reason. For example, the compressor might be locked up and if you reconnect the switches and turn on your A/C, the engine could stall. Just an example.
Hope this helps.
Lou
Old Jun 1, 2009 | 09:03 PM
Stonehenge's Avatar
Engine: 5.7
Transmission: 700R
Ok, THANKS BigBadLou! You were RIGHT! It plugged right into the front of the compressor. My a/c still doesn't work, so now I'm going to take it to a local guy. But that connector being loose was driving me nuts.. Thanks again for all your help.
Glowsock
Jan 9, 2017 04:06 PM
Caspar
Jun 19, 2016 11:19 PM
ndndndnd
Carburetors
17
Sep 5, 2015 06:24 PM
Bryan F
Aug 27, 2015 07:28 AM
Bert87
Aug 23, 2015 03:50 PM
