need to find ignition key wire please help out
Old Jun 3, 2009 | 09:14 AM
Bobby_80s's Avatar
Car: 1987 Camaro, 1986 Trans AM
Engine: V6 2.8 multi-port and V8 5.0 FI
Transmission: 5-Speed and Automatic
Axle/Gears: no idea
i bought a neat looking security item
its a key pad and you type in the right 4 digit number and it completes the circuit so when you turn the key it lets you start the car.
i can find all the wires needed except where to cut off the key ignition wire that sends the signal too the ignition in the engine.
i heard from someone the key presses a rod down the steering columb but if anyone has a direct spot where i can tap into the ignition wire from the key
please let me know, picture would be even better but whatever you guys can give me thanks
Old Jun 3, 2009 | 09:53 AM
BigBadLou's Avatar
Car: '91 Z28 convertible
Engine: TPI
Axle/Gears: 3.27 posi disc
Re: need to find ignition key wire please help out
It looks like pin C on the ignition switch will do the trick:
http://www.austinthirdgen.org/mkport...stribution.jpg
The ignition switch is on top of the steering column inside the dash. You'll need to drop the driver side knee panel and if you can't reach the ignition connectors, you'll also need to drop the steering column a little (2 or 4 15mm nuts - deep socket needed).
If you need more instructions, just search for ignition switch and you'll find plenty of threads, some even with pictures.
Btw, don't forget to use a big relay, there's a lot of current draw on that wire.
Hope this helps.
Lou
Old Jun 3, 2009 | 09:56 AM
Bobby_80s's Avatar
Axle/Gears: no idea
thanks for the help
ya the kit comes with a relay and a bypass switch incase it malfunctions and i can still start my car. just gota hide that switch haha.
ill see if i can track down the wire
looks like its a pink wire is what im lookin for. i figured orange
BRoss99
Aug 10, 2025 05:08 PM
eightsixseven
Dec 16, 2024 01:50 PM
tnrednneck
Aug 13, 2015 08:57 AM
apie2546
Aug 8, 2015 07:12 AM
