Does VSS need ECM to make Speedo & Cruise Control Work?
Old Jun 7, 2009 | 05:49 PM
88Formula383's Avatar
Does anyone know if my speedometer and cruise control will work if I removed the ECM? I swapped the TBI for a carbureted engine. There is a brown wire that runs from the VSS to the ECM. Why does the ECM need this wire? Any help would be appreciated. Thanks.
Old Jun 7, 2009 | 08:12 PM
BigBadLou's Avatar
Car: '91 Z28 convertible
Engine: TPI
Axle/Gears: 3.27 posi disc
Re: Does VSS need ECM to make Speedo & Cruise Control Work?
Yes, they will work fine on a TBI vehicle because they are not routed through the ECM (only 90-92 TPI ECM did that).
The only problem you might have after removing the ECM is the fuel prime pulse that you'll now be lacking. But if your carb bowls hold enough fuel, you should be fine without the prime.
Lou
Old Jun 8, 2009 | 08:45 PM
Thanks Lou! Yeah, the engine runs fine. No prob with the carb.
Ghettobird52
Jul 5, 2024 11:18 PM
colton_carlson
Mar 8, 2019 12:21 PM
Wade787b
Sep 29, 2015 01:15 PM
Bull86
Aug 10, 2015 05:43 PM
beachrodder
Aug 7, 2015 04:27 PM
