Where to mount temp probe on Hayden fan switch?
Old Jun 9, 2009 | 04:57 AM
RMK's Avatar
RMK
Car: 87 IROC
Engine: modded LB9
Transmission: Pro Built 700R4
I'm going to fit a Hayden fan switch as my primary fan only comes on when the secondary fan kicks in. Where is the best place to locate the temperature probe that the fan switch comes with? I'm at work so don't have the part number but it's the actual probe type that would slide between radiator fins rather than screw into the head or block.
Advice on where abouts on the radiator is the best place to put it is much appreciated.
Old Jun 9, 2009 | 04:59 AM
Twin_Turbo's Avatar
Re: Where to mount temp probe on Hayden fan switch?
As close to the inlet as possible.
Old Jun 9, 2009 | 11:14 AM
BigBadLou's Avatar
Car: '91 Z28 convertible
Engine: TPI
Axle/Gears: 3.27 posi disc
Twin Turbo is correct, that would be the right location.
However, if you are interested in fixing the problem instead of adding on to it with a hack, feel free to use this troubleshooting article to find out where the problem lies: http://www.austinthirdgen.org/index.php?pid=36
Hope this helps.
Lou
eightsixseven
Dec 16, 2024 01:50 PM
RazorN8
Jan 7, 2022 11:44 AM
Jae992
Aug 27, 2015 09:07 AM
TA8487
Aug 16, 2015 12:21 PM
