vats
Old Jun 15, 2009 | 08:39 PM
-DIABLO-'s Avatar
vats
hy guys does anyone have pics of how to dissable vats completly
my car cranks but no gas so i replace the icm and it worked fine for a day and then againg no fuel can these be vats related please help me running out of ideas
Old Jun 15, 2009 | 09:36 PM
tony_cogliandro's Avatar
Car: 1990
Axle/Gears: stock
Re: vats
seek and ye shall find.
in other words use your search button in the red line at the top of the page and put in the word VATS and you will probably find the answer repeated over 100 times.
Old Jun 15, 2009 | 10:00 PM
-DIABLO-'s Avatar
Re: vats
not the answer i was looking 4 but thanks and btw i did the search before i post and couldnt found a single guy that fixed his issue thats y i posted thanx
Old Jun 17, 2009 | 10:05 AM
BigBadLou's Avatar
Car: '91 Z28 convertible
Engine: TPI
Axle/Gears: 3.27 posi disc
Re: vats
Tony is right, just putting "VATS" in the search box gives hundreds of hits, many of them very descriptive.
"VATS bypass" search shows even closer results. It also helps to select "Search Titles Only" and the "Electronics" forum in the Advanced search. Just try it, don't be shy.
Disabling VATS is not a simple task. It's actually often much easier to figure out what the problem is and correct it.
Lou
RS Reaper
Oct 17, 2018 07:52 PM
djmarch
May 8, 2016 11:32 AM
AmorgetRS
Sep 28, 2015 09:33 PM
86White_T/A305
Sep 21, 2015 05:28 PM
Winchester1094
Sep 15, 2015 09:48 AM
