question about gm 3 wire alternators????
Old Jun 20, 2009 | 06:40 PM
my90bird's Avatar
Car: 1990 firebird formula
Engine: 5.0 tpi
Transmission: t-5
on a 3 wire gm alternator does the 2 wire connector have to be plugged in for the alternator to charge?
Old Jun 20, 2009 | 09:26 PM
afremont's Avatar
Car: 90 IROC
Engine: 5.7 TPI
Transmission: 4L60
Re: question about gm 3 wire alternators????
Yes. It can't charge without the field being "excited" by one of the wires in the plug. The other wire goes to your idiot light and it really should be in place as well. Some alternators won't charge without some kind of path to ground on the idiot light wire. Some people use a resistor to ground instead of a bulb.
Old Jun 20, 2009 | 10:32 PM
my90bird's Avatar
Engine: 5.0 tpi
Transmission: t-5
I have the plug,the small wire goes to the gauge but not sure where the larger red wire goes to.it was charging but I cut 2 wires I thought were dead and now cant figure out where one of them are.one was for me ele. choke on my carb and I'm guesing the other one was for the alternator?
any way the small wire from the connector at the alt. hasnt been touched.on the other hand the red wire has and not sure where it goes.
Old Jun 21, 2009 | 12:17 PM
afremont's Avatar
Car: 90 IROC
Engine: 5.7 TPI
Transmission: 4L60
I lied before, the idiot light is not connected to ground; it is connected to the +12V. That would be the smaller wire in the plug. The bigger wire in the plug needs to go to a switched (as in by the key) power source. Some alternators will let you cheat and connect it to the fat red wire post that runs to the battery. The rest will run your battery down overnight if you do that. You should run it to the key.
eightsixseven
Dec 16, 2024 01:50 PM
Cleotiz
Jan 6, 2018 08:56 PM
Caspar
Jun 19, 2016 11:19 PM
redmaroz
Aug 16, 2015 11:40 PM
