2nd fuse replacement... Help!!!
Subscribe
Jun 26, 2009 | 12:02 AM
I was out in the garage tonight getting my stereo all hooked up and I now have a few more questions for you if you have the time.
I noticed that my power antenna was not coming up when I turned on the tuner, so low and behold I checked the accessory fuse and it is blown... this is the 2nd fuse I have had to put in. So does this mean that I have a short somewhere in the wiring for my accessories?
Also after I hooked up the stereo and powered it on with the tuner activated I noticed that I had noise coming from the rear hatch speakers as this car was equipped with the Bose kick panel/hatch shelf speaker system. (Just an FYI though, I'm not using the Bose stuff and I'm just installing speakers run off of speaker wire.) Does this mean that I have to unhook all the bose stuff so that Im not getting this interference?
Thanks for any and all help.
Reply 0
Jun 28, 2009 | 09:38 PM
Re: 2nd fuse replacement... Help!!!
Yes, you will need to disconnect all of the Bose stuff and wire the speakers directly to the radio.
Reply 0
Subscribe
