won"t start
Old Jul 2, 2009 | 03:38 PM
bbqcrazy's Avatar
won"t start
I have a 90 trans-am & its never failed to start, untill i parked it about a year ago. i have strated & moved its a few times in between. i put 2 new batteries in it, & it seems to kill them. started it again 3 weeks ago, tried yesteday, power to everything, turn the key & nothing happens, taped starter, & hand turned motor. any suggestions would be appreciated guys. thanks.
Old Jul 3, 2009 | 02:43 PM
~~CaLi BoY~~'s Avatar
Car: 1992 Chevy Camaro
Engine: 305 Engine
Re: won"t start
Check dem Fuses probly one of em r burned
Old Jul 3, 2009 | 02:46 PM
bbqcrazy's Avatar
Re: won"t start
thanks, will try.
Old Jul 3, 2009 | 02:52 PM
armdale's Avatar
Car: 1984 Trans Am
Engine: 5.0 Litre H.O Modified
Transmission: 5 Speed Manual
Axle/Gears: 3.73 Limited Slip Posi-Trac
Re: won"t start
There is an orange heavy wire that comes from the starter to the battery. It has a fusable link [fuse] online. Bridge it and see if that helps. Otherwise the obdII security system is gone. It is what talks to your key. You would need a dealer to fix that one. Also the short that caused its failure. Might be pricey.
Old Jul 3, 2009 | 03:01 PM
goldens98's Avatar
Re: won"t start
If it is vats. You could order the lock cylinder from the dearlership get them to match the ohms from your orginal key. And install the cylinder yourself or see if you can find someone to do it. The dealership usually want 300-600 bucks. I did everything for 150. Cylinger was 75 and labor was 75. There is another way but this is if you want to keep vats.
Old Jul 3, 2009 | 06:29 PM
bbqcrazy's Avatar
Re: won"t start
will try guys thanks.
Old Jul 3, 2009 | 10:37 PM
deadbird's Avatar
Car: 87 Formula/ 00 Xtreme
Engine: TPI 305/ v6
Axle/Gears: 3.08/ 3.23
Re: won"t start
You will know if VATS is preventing startup by the 'security' light going out with key on.
Old Jul 4, 2009 | 09:18 AM
bbqcrazy's Avatar
Re: won"t start
ok
Old Jul 9, 2009 | 10:47 AM
bbqcrazy's Avatar
Re: won"t start
well i just noticed, my security light on my dash is not comeing on. at all & still no nothing. i will look for vats fuse. ( anybody please, is there a relay pehaps under hood, also? heeeeeeeeeeeeeeeeeeeelp. thanks
Orr89RocZ
Apr 25, 2016 08:28 AM
Wade787b
Sep 29, 2015 01:15 PM
SolarGoldRaptor
Carburetors
16
Aug 25, 2015 02:25 PM
92camaroJoe
Aug 13, 2015 06:07 AM
86Base
Aug 8, 2015 01:34 PM
