turn signal probmles.
Old Jul 2, 2009 | 04:11 PM
TPI TERR's Avatar
On Probation
Car: 87 IROC-Z
Engine: LsX
Transmission: MN12 6speed
Axle/Gears: 3:42
my parking light work . hazard lights work . but my turn signal dont. neither front or rear.
checked fuses. and flasher .. both good. what can it be?
Old Jul 2, 2009 | 06:02 PM
Smoke_Jaguar's Avatar
Car: 1986 Camaro T-Top
Engine: 2.8L V6 (MPFI)
Transmission: 5 Speed
Re: turn signal probmles.
Probably a dumb question, but did you check all your bulbs? A burned out bulb(s) can stop the flasher from working and turning on the hazard lights will make up for the loss in amperage allowing the flasher to work.
Old Jul 2, 2009 | 06:38 PM
TPI TERR's Avatar
On Probation
Car: 87 IROC-Z
Engine: LsX
Axle/Gears: 3:42
but all the lights are working properly.. im guessing its the cam switch inside the column.
Old Jul 18, 2009 | 04:22 AM
TPI TERR's Avatar
On Probation
Car: 87 IROC-Z
Engine: LsX
Axle/Gears: 3:42
need help again. !
so i figured out the problem it was the flasher that is kinds hiddednunderneath the dash. i believ the one is surrounded by other relays is for the hazards.
but a week later after replacing the flasher i came across another problem .
so i got a ticket today for this
my front turn signals are working . but not my rears..
Old Jul 18, 2009 | 06:23 AM
DJP87Z28's Avatar
Car: 1987 Black IROC-Z (SOLD)
Originally Posted by TPI TERR
need help again. !
Burnt out bulbs..When you replace them do all (3) it will save future work tearing the backend apart. You need (2) p/n 1156 & (1) 2057. The pins are different on the sides.
Old Jul 18, 2009 | 11:40 AM
TPI TERR's Avatar
On Probation
Car: 87 IROC-Z
Engine: LsX
Axle/Gears: 3:42
new bulbs. and im only getting the rear driver side turn signal working..
83 Crossfire TA
Jan 3, 2016 01:26 PM
bbsr72
Sep 27, 2015 05:55 AM
TrevinE
Sep 14, 2015 03:20 PM
83 Crossfire TA
Sep 8, 2015 12:06 PM
