Somethings draining my battery!
Old Jul 6, 2009 | 06:55 PM
Mowgli's Avatar
Hi all, been awhile since I have worked on my 84 z28 due to being in training and Iraq. But now, I am back and ready to get my diamond in the rough smoothed out. lol
Starting with a fully charged battery, I can get one maybe two startups out of my car. After that, it's dead. I can jump it with my truck, but takes awhile before it'll crank all the way over!
Is something not charging it correctly or is something draining it?
By no means am I a mechanic, but due to money and the lack there of, i would like to do as much possible myself. It is a complete rebuild/restoration, saving some green here and there will really help.
Thank you in advance,
-Jon
Old Jul 6, 2009 | 07:05 PM
JTNKTZ's Avatar
Car: 1991 Camaro RS/1989 Vert RS
Engine: 355/350
Transmission: T-5/T-5
Axle/Gears: BW9bolt3.45posi/3.23 Posi
Re: Somethings draining my battery!
Get a voltmeter. They are one of the most handy tools you can get.
Charge the battery completely.
Check the voltage.
Keep starting until goes dead.
Check voltage. If it's above 8v it should start. If not then your starter is probably bad.
Old Jul 6, 2009 | 07:11 PM
Mowgli's Avatar
What do I need to test the altenator?
I will pick one of them up from autzone.
What are other possibilities?
Old Jul 6, 2009 | 07:12 PM
JTNKTZ's Avatar
Engine: 355/350
The battery.
When you last start it, does it go down slowly or does it spin at full speed and when you try again it does nothing? Maybe hear a click?
Old Jul 6, 2009 | 11:55 PM
Billy_Bob's Avatar
Car: 92 GMC Sierra 2500
Engine: 5.7l
Transmission: 4L70
Axle/Gears: GT4 3.73
A fully charged battery should be 12 something volts with the ignition on. (The ignition on places a load on the battery. Use voltmeter)
Then the battery should read 13/14 volts after starting and the alternator is charging the battery.
If the battery is low, get a battery charger and charge it.
If the battery keeps draining and you are not getting a higher voltage after starting, then this would be a problem with your charging system. Many times the alternator.
Frozer!!!
Jan 19, 2024 04:55 PM
83 Crossfire TA
Jan 3, 2016 01:26 PM
SlowAZ28
Sep 2, 2015 05:19 AM
