Tech Questions
Old Jul 14, 2009 | 06:14 AM
BlackTopKing's Avatar
Car: 1987 Trans Am GTA
Axle/Gears: Posi 3:42
Tech Questions
Hey everyone, I have tried for a couple days to figure this out on my own, but I have not made any progress. So I thought to see what you guys think before I did anything else.
I notice that when I hit a bump the car now throws a check engine light at this time the car will bog out...kinda feels like the timing retarts. but its not the whole time just during the bump.
if i hit another the light goes out.
So on the way to work I play. Lights on-Light out...
I thought that maybe the bumps were setting the Knock sensor off- I checked 4 or 5 times and nothing that I can see or tell is there.... The sensor was new with the completion of the build so maybe a year old now.
also when I pulled the code from the ECM- I got code 13....O2
so I checked, sensor also looks ok and as did the wiring.
I will attempt to get a V-Meter to try to test,
But it dont really sound right, unless the O2 sensor is messing up the Air/gas and that causes the odd feeling.
Either way light off - car is running like a CHAMP, light on and its not 100%....
I thought to just change the sensor but....in my mind if that was the cause i would have a light all day...not just when I hit a bump.
So my thought is a connection of some kind-hit bump and it breaks causing light hit bump and it connects turning light off.
So hopefully someone has an ideal.
let me know please
thanks
specialized
Jun 18, 2022 09:26 AM
Cleotiz
Jan 6, 2018 08:56 PM
gixxer92
Sep 1, 2015 04:32 PM
sailtexas186548
Aug 24, 2015 10:11 PM
redmaroz
Aug 16, 2015 11:40 PM
