Solution for 140 amp Alternator on Serpentine
Old Jul 15, 2009 | 04:23 PM
darbysan's Avatar
Car: 1985 El Camino Choo Choo
Engine: L31 Crate 350 w/ TPI
Transmission: GN 200-4r
Axle/Gears: GN 8.5 3.73
Thanks to a fellow member on the MCSS forum, I employed his solution for installing a CS144 140 amp alternator on my Serpentine setup. The trick turned out to be selecting an alternator for a 1996 C1500 truck. While a slight mod needs to be made to the Alternator bracket, moving one of the bolt holes about 1/4" , it was otherwise a direct bolt in. You will still need to do the wiring mods for CS144 conversion, but I think that has been covered pretty well in other threads.
You can see his write-up here.
http://www.montecarloss.com/communit...93&#Post703993
jrdturbo
Mar 31, 2016 02:58 PM
SRKLEGIN
Oct 29, 2015 06:38 PM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
SRKLEGIN
Oct 3, 2015 10:11 PM
raymondandretti
Sep 27, 2015 06:43 PM
