Crossfire Fuel Pump Wiring....
Old Oct 27, 2003 | 09:12 PM
406-IROC's Avatar
Car: '86 Camaro
Engine: 406 Small Block
Transmission: 4 Speed
Axle/Gears: 3.45
I'd like to install an 83 Crossfire intank fuel pump in my 86 TPI's tank (converting to Carb). If I maintain the stock TPI's fuel sending unit, will there be any problems as far as obtaining the right voltage, or hook-up etc...
(I'm trying to avoid an aftermarket pump, and would like to run with a much less 'psi' intank pump, along with the Mallory AFPR)
ANY feedback would be appreciated!
Old Oct 28, 2003 | 09:37 PM
snisbet375's Avatar
Car: 1983 camaro z-28
Engine: 305 crossfire
i have an 83 crossfire. i had to replace the tank and the pump. I replaced it with an 87 fuel tank. The only thing that i ran into was that i had to cut the conectors and switch them. Just reversed them. It was a pretty simple job.
Old Oct 28, 2003 | 10:26 PM
406-IROC's Avatar
Car: '86 Camaro
Axle/Gears: 3.45
Thanks for the reply!!!
Somebody mentioned 'ring connectors' for the Crossfire harness hook-up, and that they screw into the body of the pump with two screws....
I didn't get the chance to pick one up today (luckily the Pep Boys by me has three in stock).... but we're talking a simple three wire hook-up conversion, no?
It'd be a simple 'posi lock' wire connector job, and not a solder job, no?
Thanks again....
Old Oct 29, 2003 | 06:53 AM
Jproz1167's Avatar
Car: 1982 Trans Am & 1982 Corvette
Engine: L-98 with LO-3 induction. 350 CFI
Transmission: 5 speed and vette has 700r4
Axle/Gears: 373's in T/A .. vette unknown
406iroc
have you considered a 84 5.0 h.o intank pusher pump, they make around 5 psi, the cfi pump I would imagine would be a little much, granted your running a regulator, my 84 had this from the factory the pusher pump and the mechanical pump
Old Oct 29, 2003 | 06:41 PM
snisbet375's Avatar
Yah i just used them little color things that you crimp together that conects two wires. Not sure what they are called. But yah on a crossfire the wire were screwed onto the fuel pump and the 87 i think pluged in. I just cut the wires and crimped the new conectors on and it hasnt blown up yet =)
Old Oct 29, 2003 | 07:57 PM
406-IROC's Avatar
Car: '86 Camaro
Axle/Gears: 3.45
Originally posted by Jproz1167
406iroc
Yeah, I originally wanted to install a mechanical pump with the matching intank pusher, but whoever had the car before me installed a later model roller cam with the missing lobe...
Old Oct 29, 2003 | 08:03 PM
406-IROC's Avatar
Car: '86 Camaro
Axle/Gears: 3.45
Yeah I see what you mean now, as I just picked up a CFI pump ealier today. My crimp connector is a real cheapie piece, so I'm going to solder the connections together...
Worst come to worst, the pump will burn out on me.... but I don't think it will (especially with a AFPR with a return line). But we shall see.....
Old Jul 15, 2009 | 04:25 PM
KITT1983's Avatar
Car: 1983 Pontiac Trans Am Daytona 500
Engine: Crossfire 305ci V8
Transmission: Jasper 700R4 4 speed Automatic
Axle/Gears: 3.23 limited slip/posi
Re: Crossfire Fuel Pump Wiring....
any updates on your progress?
Glowsock
Jul 24, 2025 03:15 PM
92camaroJoe
Jul 29, 2023 07:57 PM
RazorN8
Jan 7, 2022 11:44 AM
beachrodder
Aug 25, 2015 08:05 AM
92camaroJoe
Aug 13, 2015 06:07 AM
