FPH FUEL sending unit?
Old Sep 17, 2007 | 08:34 PM
stevenb's Avatar
Car: 87 camaro
Engine: 357 swap
Transmission: t5
I am in need of a new sending unit and I was told I need to check to see if I need an FPH sending unit and to check the wiring harness for a print of FPH on the sending unit? Am I checking the right spot? What is it and if I dont have it what does it mean?
Old Sep 18, 2007 | 06:18 PM
stevenb's Avatar
Car: 87 camaro
Engine: 357 swap
Transmission: t5
Re: FPH FUEL sending unit?
Old Sep 24, 2007 | 09:39 AM
klause83z28's Avatar
Car: 83 z28
Engine: boat anchor 305 (ex CFI)
Axle/Gears: 3.23 10 bolt
The letters will be on a yellow piece of paper taped to the harness that comes off the connector comming from sender/pump. The only thing I can think of is that the letters designate particular lengths of harness... as bizzare as that sounds.My sending unit is out on my z, and have yet to replace it. I keep hearing over and over that any sender will work, but you have to cut and spice wires. I finally bought one(sender) off of a member here and am hoping that I can get it in soon. MY letters are FPC, my connectors are black and the sender I bought are yellow.
Cheers!!!
Old Sep 24, 2007 | 12:25 PM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
A picture is worth a thousand words !!!!!
The first pic is from an 1983 Carb: "FAA"
The second pic is from an 1986 MPFI: "FEM"
All of the Carb Pick-up connectors I've seen are black and have 2 wires - just for the fuel guage. Most of the MPFI, TBI and TPI connectors I've seen are yellow - but I've seen Orange as well. Those are 3 wire plugs, The additional wire is for the Fuel Pump.
Attached Thumbnails FPH FUEL sending unit?-pickupplugcarb.jpg   FPH FUEL sending unit?-pickupplugmpfi.jpg
Old Sep 25, 2007 | 09:50 AM
Car: 83 z28
Thank you for the pics, that is helpful. However, my crossfire car I was talking about had a 3 prong and it's black. I wonder if it's set up by year?
Old Jul 15, 2009 | 04:27 PM
KITT1983's Avatar
Car: 1983 Pontiac Trans Am Daytona 500
Engine: Crossfire 305ci V8
Transmission: Jasper 700R4 4 speed Automatic
Axle/Gears: 3.23 limited slip/posi
any updates on your progress?
Glowsock
Jul 24, 2025 03:15 PM
Ghettobird52
Jul 5, 2024 11:18 PM
Infested
May 22, 2018 11:56 PM
Irocohio
Aug 12, 2015 08:03 AM
