head light problem and brights problem
Old Jul 16, 2009 | 04:43 PM
scoutsniper's Avatar
Car: 2000 TRANS AM
Engine: H,C,I LS1
Axle/Gears: 3.42 posi
well i have a 1991 firebird formula. i tried to use my brights a couple nights ago and i had to hold the turn signal switch to keep them on. well on my way home i noticed they were stuck on and i cant click them off? how do i fix that?
also my passanger headlight wouldnt go up all the way. so i found a thing online to were you can spin the headlight gear 180* and use the other side thats good. well when i was trying that it didnt work. so then i was holding my headlight up trying to get the arm back on to the motor. and i snapped the top of the headlight bracket on one side.
i found a guy who can give me a entire headlight assembly for 20$ thats motor, bracket, everything. but its from a 86 model. so can i use the motor and bracket tray and just swap everything else over?
i need to know by sunday b/c thats when im suppose to go buy it.
thanks. if something didnt make since. point it out and ill try to reexplain it.
Old Jul 16, 2009 | 06:29 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Re: head light problem and brights problem
The dimmer problem is the switch - it needs readjusted - it's under the column all the way under above the brake pedal - youll see the rod that actiavates the switch moving - lay the seat back all the way down, get a small flashlight, and crawl in with your head in the floorboard, and your feet on the headrest on your back - it's a PITA, but that's where it's at. Oh - take a 7mm short wrench and socket/rachet with you!
Old Jul 17, 2009 | 09:32 AM
BigBadLou's Avatar
Car: '91 Z28 convertible
Engine: TPI
Axle/Gears: 3.27 posi disc
As Camaronewbie says, it's likely the adjustment of the dimmer switch. Article with the adjusting procedure here: http://www.austinthirdgen.org/index.php?pid=16
Hope this helps.
Lou
Old Jul 17, 2009 | 03:17 PM
Car: 2000 TRANS AM
Engine: H,C,I LS1
well i tilted my wheel all the way down and it clicked and turned them off. so now im not worried about it.
any clue on if a 86 headlight will work on a 91?
Old Jul 17, 2009 | 03:19 PM
BigBadLou's Avatar
Engine: TPI
The bulb? Yes.
The assembly with the motor? No.
Lou
Old Jul 17, 2009 | 05:36 PM
Car: 2000 TRANS AM
Engine: H,C,I LS1
can i use the headlight motor?
Old Jul 19, 2009 | 07:48 PM
Car: 2000 TRANS AM
Engine: H,C,I LS1
well i got the headlight in and everything fit and worked once.
the lights are turning on and the car is grounded fine. but i have to reset the ground everytime to get the headlight motor to work. i messed with the relay but that didnt seem to work? i cleaned the ground for the motors and everything. but nothing seems to work but reseting the ground.
any help please?
TheJoeY88
Dec 31, 2016 07:30 PM
justin57
Aug 20, 2015 07:05 PM
Tony Ferrarri
Aug 11, 2015 07:59 PM
Omega
Aug 10, 2015 12:46 PM
