factory tach not right
Old Jul 22, 2009 | 12:34 PM
jamesw343's Avatar
Car: 1986,1988,1989 IROC
Engine: ?,L98,383 L98
Transmission: ?,700r4,700r4
Axle/Gears: ?,3.27,3.45
just got 1989 iroc running but tach reads way off.With scan tool hooked up factory tach reads 1500 rpm and scan tool reads 800 rpm.The only thing i added to ignition is MSD blaster coil.Thanks in advance
Old Jul 22, 2009 | 09:14 PM
GILLIGAN's Avatar
Car: 1992 RS
Engine: BLACK&DECKER AQUARIUM PUMP
Re: factory tach not right
From what I have read about the blaster coils some of them need a tach adaptor for the tach to read correctly there is also something called a tach signal spliter and it prevents the tach from getting two impulse signals which sounds like what may be happening since the reading is about double I would check on both hope this gets you on the right path
$750 L98
Feb 1, 2025 02:25 PM
armybyrd
Sep 28, 2023 12:16 AM
IROCTheHouse
Exterior Parts Wanted
Oct 26, 2015 02:35 PM
Eric-86sc
Sep 28, 2015 11:37 AM
SS-EXPRESS
Sep 28, 2015 09:14 AM
