Got an 86 iroc non pull down model. I push the hatch unlock and nothing happens. What is the issue here? Thanks
JamesC
close
Quote:
Relay perhaps, which is in the console, IIRC. BTW, I have that issue from time to time. I simply clean the hatch contacts and all's well.Originally Posted by Hartmann
Got an 86 iroc non pull down model. I push the hatch unlock and nothing happens. What is the issue here? Thanks JamesC
The motor may need to be reset. Theres a tab right beside the latch (in the hole drivers side i think) that needs to pushed down. Sounds like the motor may not have hit bottom.
There is alot of info on this topic. Search hatch wont close or hatch wont open. Could be a number of things but resetting is simplest check.
JamesC
close
Quote:
He has a grab-it-and grunt version, no motor.Originally Posted by 86sdubzzT/A
The motor may need to be reset. JamesC
Mine is doing the same thing, except mine has the pull down. Whats the contacts and do you know where the relay for mine is? its a 91 bird. I really need to get it fixed because I dont have a key to release mine. I have my cut off switch there, so i have to reach threw the back, and that dont work well I am too fat for that stuff thanks!!!
Former Sponsor
If you can pop the hatch open and you can hear it trying to release but it does not,the catch on it may need a little white grease to free it up. I'd try this out.
let us know how you made out.
I have no key to open it so maybe that will come into play here. Weird, thing was it was working great a while ago, just now its not. Also my dome light is not working either. Whether or not they are connected is not certain. So I had a low bat today, but plenty to turn it over, but not start. I will charge er up and try tomorrow. From what I remember though I pressed the switch and got nothing at all.
Don't have a key to open it and still no luck on opening it up. Should I replace the relay, it is in the area near the horn relay correct?
