Bare minimum of wires to run a carbed 350?
Old Jul 28, 2009 | 07:47 AM
rubbermanZ28's Avatar
Car: 84 Z28
Engine: 355c.i.
Transmission: Turbo 350, w/shift kit
Underhood stuff....Tach, Ignition, alternator, starter, battery, choke ( if i have one) coolant temp, oil pressure. Am i missing anything?
Old Jul 28, 2009 | 08:58 AM
92RS_Ttop's Avatar
Car: 1992 Camaro RS
Engine: Rebuilt 350 going in after paint
Transmission: WCT5, 7k & counting behind the 350
Axle/Gears: 4thgen disc rear w/ 3.73 Posi
Re: Bare minimum of wires to run a carbed 350?
Other than the block ground, that looks like everything you'll need to connect to the engine.
Other stuff under the hood would be the wiper motor, radiator fan, washer fluid pump, blower motor, A/C stuff if you're running that, power steering, brakes, speedo sender if its electrical, and the lighting and horn wiring for the front end.
Old Jul 28, 2009 | 09:20 AM
Car: 84 Z28
Engine: 355c.i.
Does it matter where i run the block ground from on the engine? Or is it all fine as long as i have a good connection?
Old Jul 28, 2009 | 09:44 AM
92RS_Ttop's Avatar
Car: 1992 Camaro RS
The negative cable from the battery should bolt directly to the engine. I have mine going to an accessory hole in the cylinder head. Then there is the braided steel ground strap that goes from the engine to the body. I have mine in one of the accessory holes in the rear of the passenger side cylinder head and it just goes to a bolt screwed into a hole in the frame rail on that side. I ground the paint off underneath the bolt head so it gets a good ground.
Old Jul 28, 2009 | 10:43 AM
Car: 84 Z28
Engine: 355c.i.
Ok cool. Thanks While im building my 350 up, i have a 305 that i got for free that im putting in, just so i can drive it around a bit, and move it easier.
MustangBeater20
Oct 29, 2022 09:20 PM
specialized
Jun 18, 2022 09:26 AM
midge54
Dec 27, 2019 04:14 PM
camaro11j
Sep 19, 2018 08:49 AM
theshackle
Mar 5, 2017 06:37 PM
