Engine swap, need help fast...
Old Jul 29, 2009 | 10:46 PM
jonnybcamaro's Avatar
Car: 02 T/A
Transmission: Built 4L60E
Axle/Gears: 3.42 Posi
I am swaping from a 2.8 MPFI to a L98 TPI. I have a painless wiring harness for the engine and the correct ecm. Do I need to run any wires from the drivers side to the ecm? I pulled the motor and tranny, saw all the wires that run across the fire wall (after I separated a lot of them between engine harness and other) I am just confused at the amount of wires still going from the drivers side to the ecm. PLEASE HELP ME!!!!
Old Jul 30, 2009 | 02:55 PM
groundrat's Avatar
Car: 91Z28
Transmission: WC T-5
Axle/Gears: 10 Bolt Posi, 3.08
Re: Engine swap, need help fast...
At a minimum you will have your ALDL, SES light, and other gauge wires.
Frozer!!!
Jan 19, 2024 04:55 PM
camaro11j
Sep 19, 2018 08:49 AM
theshackle
Mar 5, 2017 06:37 PM
sreZ28
Aug 14, 2015 07:48 PM
bradleydeanuhl
Aug 12, 2015 11:48 AM
