75 firebird dash lights
Old Aug 2, 2009 | 08:22 PM
GTA350VORTEC's Avatar
Car: Black on Black 1989 GTA
Engine: 5.7L Vortec TPi
Transmission: 6 Speed T56
Axle/Gears: 3:73
Im currently working on a 75 firebird and cannot get the dash lights to work, does anyone have a wiring diagram available? Thanks!
Old Aug 3, 2009 | 11:11 PM
Axle/Gears: 3:73
Re: 75 firebird dash lights
BUMP
Old Aug 4, 2009 | 11:41 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
75 would be a 2nd generation - this site is for 3rd generation cars - we wouldn't have a clue!
Old Oct 30, 2009 | 02:57 AM
Axle/Gears: 3:73
Would anyone have a clue as to where I can find a wiring diagram for this issue?
Old Oct 30, 2009 | 03:48 AM
Twin_Turbo's Avatar
What dash lights? the warning lights or the gauge illumination.
I'm thinking you mean gauge illumination, in that case, did you turn the dimmer ****? If that doesn't help it's most likely the rheostat in your light switch. You can pull the switch and re pin the wire from the rheostat to bypass it, your dimmer wont work, if you want to do it the right way, get a new switch
Old Oct 31, 2009 | 06:51 AM
CreepingDeath94's Avatar
Car: '87 Trans-Am
Engine: LB9 (305 TPI)
Axle/Gears: 3.42 or 3.73..figuring it out still
Well, it looks like there is one of those instrument cluster printed circuit board style panels for the dash/instrument cluster itself on a '75. I have found that if the wiring for the illumination is sending signal to illuminate (white or gray wires seem to be illumination related on the interior), it can be those circuit boards have some corrosion on the contact points where the little bulbs screw into place. If that is the case, it can be cleaned up/oiled with some contact oil...just remove the corrosion wherever you see it. My wiring diagrams I have are from Chilton and Haynes manuals and are less than clear and helpful...that's just what I gathered from a look at them...I have no way of downloading it and sending a diagram though...sorry. Hope this helps some.
justin57
Aug 20, 2015 07:05 PM
stalkier
Aug 13, 2015 12:59 PM
tnrednneck
Aug 13, 2015 08:57 AM
Omega
Aug 10, 2015 12:46 PM
apie2546
Aug 8, 2015 07:12 AM
