84 berlinetta digital electronic cluster problem...
Old Aug 3, 2009 | 10:59 PM
unclejoe's Avatar
Car: 84 berlinetta
Engine: 305 v8
Transmission: auto
i have an 84 berlinetta, and i am working on replacing the whole cluster... i am working on getting a new one, but i need to get the old one out... i have the shop manual for it, and it has the step-by-step instructions... the only part i don't understand is where it says to remove "(2) steering column bolts"... what exactly does that mean? i have everything else detached and the only thing still holding it in is the cable... i can't get it undone... any suggestions?
Old Aug 4, 2009 | 06:35 PM
osirus's Avatar
Car: 89' RS
Engine: 350 TBI
Axle/Gears: 2.73 posi
Re: 84 berlinetta digital electronic cluster problem...
A sawzall should do the trick.
Old Aug 5, 2009 | 06:49 PM
ParkerTPIz's Avatar
there are 2 13mm steering column bolts down on the underside of the steering column. You have to first remove the covering (they are torx head fasteners) and then remove the 2 13mm nuts. Removing those will allow the coulmn to drop and that will allow easy access when removing the cluster.
Although u do not need to drop the column it does make things easier to get at.
I think the speedo cable just unscrews out of the back of the cluster.
InfernalVortex
Apr 20, 2021 11:31 AM
sheachopper
Jul 31, 2019 11:27 AM
Lbibb
May 5, 2016 12:00 AM
Linson
Oct 1, 2015 09:50 PM
rusty vango
Sep 29, 2015 02:44 PM
