ECU Swap
Old Aug 4, 2009 | 08:01 PM
tonygia's Avatar
ECU Swap
I have a 1990 Firebird, Trans Am, GTA. In the last 7 years it has been going through some major changes. Generally, I have converted it from a 5.0L automatic to a 5.7L, 6-speed. The overhaul is almost complete, however, I have run into a problem with the ECU. The current ECU has an Hypertech chip installed in it. I do not know what the characteristics of this chip is as it came with the car when I bought it. Needless to say, this chip does not like the 5.7L engine at all. I can start the car but the cold idle is rough and the hot idle is rougher. I am considering replacing the existing OBD1 with an OBDII ECU which would allow me to program the parameters or even replacing the existing ECU with a stand-alone ECU. I am not sure which is the best method and was wondering if anyone can provide some background to either of these options.
Old Aug 5, 2009 | 06:45 PM
ParkerTPIz's Avatar
Re: ECU Swap
try reposting this or asking someone in the DIY PROM or DFI and ECM sections u may have better luck there
eightsixseven
Dec 16, 2024 01:50 PM
italiano67
Dec 11, 2016 09:21 AM
Caspar
Jun 19, 2016 11:19 PM
E Rod
Aug 28, 2015 05:17 AM
nuggie
Aug 25, 2015 01:27 PM
