blower motor
Old Aug 5, 2009 | 02:42 PM
TPI TERR's Avatar
On Probation
Car: 87 IROC-Z
Engine: LsX
Transmission: MN12 6speed
Axle/Gears: 3:42
blower motor
there is a red wire by the harness and the black wire for ground. is the red wire a 12v source or only with ignition?
Old Aug 5, 2009 | 06:43 PM
ParkerTPIz's Avatar
Re: blower motor
not sure...u try hookin a volt meter up to it?
what exactly is the problem?
Old Aug 7, 2009 | 11:47 PM
82CrossFire Z28's Avatar
Car: 82 Camaro Z28, 88 IROC-Z
Engine: 5.0L TBI., 5.7TPI
Transmission: Auto TH200C, 700R4
Axle/Gears: 3.23 posi, ones that rotate!
Re: blower motor
In the 1987 and earlier cars with a V-8 and the engine cooling fan, the black wire is ground, the red wire is for the blower motor High Speed setting and the purple wire is for the blower motor lower speed settings on the blower switch.
The Red wire goes to fusible link B which is 16 gauge Orange and HOT all the time. Depending on the additional load you may want to connect to this wire, you may melt the fusible link if you run the blower motor at high speed with the additional load turned on.
Frozer!!!
Jan 19, 2024 04:55 PM
Bubbajones_ya
Aug 31, 2015 12:02 PM
zayne0
Aug 24, 2015 07:22 PM
mhatfield 14
Aug 15, 2015 10:47 AM
Street Lethal
Aug 13, 2015 08:28 PM
