Identification of Harness End
Old Aug 10, 2009 | 07:56 PM
resinlake's Avatar
Car: 2011 6.2 Silverado, 88/85 camaro
Hello, I just finished my quicksilver install, getting all of my wires cleaned up in the car after swapping everything from the 88 to the 85 so that I can go register it and need help identifying this one harness plug end. I took a picture of the end that slides or plugs into something and a picture showing the colors of the wires. They are Orange, White, Off-White/Tan, and Black. Wires are approx 14-12 ga. wire.
Thanks ahead of time!!!
Old Aug 11, 2009 | 08:05 PM
resinlake's Avatar
Re: Identification of Harness End
If it helps, the plug end says "PACK-CONN" on it.
Old Aug 11, 2009 | 08:17 PM
bradley23150's Avatar
Car: 83 Trans Am / 96 Jeep XJ
Engine: 355 / 4.0 I6
Transmission: TH350 / Auto
Axle/Gears: 3.23 10-bolt / 4wd
Where is this located?
Do your turn signals work?
Old Aug 11, 2009 | 08:20 PM
resinlake's Avatar
I can't get out to the shop right now but will drive out there first thing in the morning to double check the turn signals, pretty sure they work. This harness connection is on the driver side, under dash, right next to the power distribution block the different wires plug into.
Old Aug 11, 2009 | 09:13 PM
I 'think' Ive seen this same plug on my car, and it plugs into another connector hanging off of a wire, but the connector looks totally different than what you would expect, its hard to explain, just look for another missing connection.
Old Aug 14, 2009 | 07:33 PM
resinlake's Avatar
bradley2150, I looked for a connection, I do not see one under there, and no, for some reason my turn signals are not working but my emergency flashers do.
Old Aug 14, 2009 | 07:38 PM
tony_cogliandro's Avatar
Car: 1990
Axle/Gears: stock
that looks like aftermarket.
gm uses a propriatary plug/s and when i have to hack into them i cant just get the same plug to fit, i have to make up a harness connection.
Old Aug 14, 2009 | 08:12 PM
If I get a chance, Ill see if I can snap a pic of what I am talkin about.
Old Aug 14, 2009 | 08:16 PM
resinlake's Avatar
i appreciate the reply's guys, I really do. I took it out for a full test run tonight with insurance and registration on it, first time in 7 years, it was unbelievable, you know like that first time driving a camaro. I had an adrenaline rush and was shaking just a bit. I really like the Transgo full-manual kit w/ quicksilver shifter, exhaust through the powerstick. Just need to get all the bugs worked out now
Old Aug 24, 2009 | 10:46 AM
resinlake's Avatar
Ok, grabbed the camera and took some hi def pics so that it is clearer as to what I am talking about, could also use some help with a couple other wires. This car has no stereo, no AC, no Heat, no smog, just the lights, gauges, MAF, engine sensors and ECM. Car must have VATs bypassed because the old columns ignition would start car without a key in it, so I kept the column from an '85 and its key which has no chip and the '88s ECM doesnt fuss at all, car starts right up.
What are these wires for?
TheJoeY88
Dec 31, 2016 07:30 PM
sweet_87_iroc
Sep 25, 2015 10:01 PM
fbirdroller
Sep 2, 2015 10:27 PM
zayne0
Aug 24, 2015 07:22 PM
jharrison5
Aug 19, 2015 05:53 PM
