PLEASE HELP!!!!!
Car: 89 camaro iroc z28
Engine: 355 carbed
Transmission: t-5 speed
Axle/Gears: 2.73 posi drum rear
PLEASE HELP!!!!!
my camaro will start and run fine when its cold, when the motor is warmed up and i shut it off it wont start. i checked the fuel rail and i got 42psi, checked spark and i have that. open up the throttle body and spray starting fluid, turn the key and let fuel pump run then start it with my foot on the gas and it starts. when its warmed up it idles kind of funny but then i give it gas and its good. i just bought an ecm, fuel pump, plug wires, ignition coil, fuel filter, changed oil & filter, i think the PROM might be bad but idk, i changed the ecm cause it got hot when i drove and the motor warmed up but it didnt come with the PROM. the 3 things for ignition are there but when its warmed up something is telling the fuel injectors not to fire right idk...... please help me solve this nightmare so i can still run the tpi
PS. the car sat for a while so thats y i changed the fuel filter/pump and oil/oil filter
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: PLEASE HELP!!!!!
Have you tried changing the ignition module? It's inside the dist, under the rotor. They can go bad and not work well when they get hot.
Engine: 355 carbed
that was replaced but, the guy at the shop that replaced it ****ed up the rotor cap insid the distributor, switched two plug wires and the electrical caps that go on the ignition module werent on all the way
Car: 1992 RS
Engine: Carbed 350
That's why I NEVER let anyone work on my cars - I can mess things up myself and it's way cheaper!
Plus, I get to learn - 5 years ago I had no clue about anything Camaro/Firebird related, and now I've had cars 3 apart and put back together. Maybe sad, but I used to dream about girls - now I dream about Camaros! (Maybe I'm just getting old)
At least my Camaro will never leave me AND take everything I have (it won't all fit).
At least my Camaro will never leave me AND take everything I have (it won't all fit). Thread Starter
Engine: 355 carbed
i didnt pay for it when it was at the shop, the dude i bought it off paid for it lol, so what do u think is wrong with it?
Car: 89 FORMULA 350
Axle/Gears: 327
Engine: 355 carbed
yea i agree with you 100%, my car is at my friends shop tho and hes changing the whole distributor. he said that theres a coil on the inside of the distributor that dosnt like to polorize when hot. he also told me when warm the test light would dim out on the injectors, y hes changing the distributor idk, but i purchased accel injectors off of summit, 24lb/an hour. im pretty sure those r the same as stock
Car: 89 FORMULA 350
Axle/Gears: 327
I thought 19# was stock for 305 and 21# for 350 (L89), you don't want too much fuel.
I have the same problem, 91 Z28 w 1987 L98 350 TPI 400 R4, gets hot, shut it down and then it won't start till it cools, Some suggest that i move my coil because they think it's getting to hot (temp ~180 - 200 range) Any one tell me where a Horn relay is and i need to replace turn signal switch
Thanks for your help very one
Burbo
Burbo
Thanks for the reply, i guess i don't know what to do or where to start
1st Ignition module, Fuel Injectors, know fuel pump relay. Where is that located
Thanks for your input
Car: 87 gta
ok. i do have the same problem.
dumb luck let me find a way to start the car when problem happens.
next time you drive the car and you shut it off when it does not restart open ecm unplug chip and plug back in. mine fires up instantly after i do this.
1 thing i noticed was my digi fuel pressure gauge dropped line pressure after i unplugged chip from ecm.
so i replaced ecm with known good spare i have same issue unplug chip plug back in car fires right up.
tried just replacing chip same issue....
leads me to believe a ground or relay issue.
for the time being i have my ecm on the passenger floor. i drive whenever i wan't. if car wont start i unplug chip plug back in watch fuel pressure drop and car fires up
