pickup coil problems
Old Aug 21, 2009 | 07:56 PM
89iroczNGa's Avatar
Car: 89 iroc
Engine: 350 tpi
Transmission: auto
Axle/Gears: 2.77
my tach keeps jumping, needle is spazing out, ive replaced dist two times on count of this and both times it cleared up for couple months and comes back. starts with needle jumping only then progresses to engine skipping after couple days. any advice please?
Old Aug 24, 2009 | 08:58 AM
XCellerate's Avatar
Car: 87 IROC
Re: pickup coil problems
Same problem here...just replaced the cap/rotor/wires with Accel and new MSD Blaster coil. Anyone have an answer out there?
Old Aug 24, 2009 | 07:39 PM
89iroczNGa's Avatar
Car: 89 iroc
Engine: 350 tpi
Transmission: auto
Axle/Gears: 2.77
may have a coommon link now, I also have accell cap, rotor, and plugs and also the msd blaster coil hummmmm..? anyone else with same cap, plug wires, coil having or had same problem? cannot keep changing distributer I know that
Old Sep 14, 2009 | 07:10 PM
chevyfanman's Avatar
Car: 1991 camaro rs
Engine: tbi 305
Axle/Gears: its kinda low
ive got accel 8.5 wires and msd coil and ive had 3 dizzys in this car since ive had it is it the pickup coil or control module
Old Sep 15, 2009 | 11:21 AM
Theking's Avatar
Car: 1989 IROC-Z
Transmission: Th700R4
I changed to a MSD 8366 Dizzy, MSD Blaster coil, and MSD 8.5 Wires last year.
My rpm needle jumped all over, sometimes got stuck at 7000rpm when cranking.
Turned out to be a bad pickupcoil and a bad ignition module (on the brand new MSD diszzy) Got them swapped out and the car was fixed.
So check the dizzy again, if either one of them are broken (module or pickup) and you change the module and its the pickup thats failing, you can break the new module. So be sure both are fine.
Also check all grounds and battery voltage when the problem acoours..
Azrael91966669
25
Jun 20, 2017 04:04 AM
apo_bailon15
Mar 28, 2016 05:20 AM
Winchester1094
Aug 18, 2015 10:23 AM
92camaroJoe
Aug 13, 2015 06:07 AM
