tpi wiring help!!
Old Aug 23, 2009 | 10:02 PM
robscamaro91's Avatar
Car: 91 Camaro RS
Engine: 305tbi out, 350tpi goin in
tpi wiring help!!
hey guys doing a tpi swap into my 91 camaro. for the most part my tpi harness matched up pretty good except that the purge canister is on the pass. side unlike my tbi harness where my purge canister is on the driver side. anyways there was like 4 wires that were cut just need some help identifying. these are from the loom that splits right where the harness comes out into the engine bay that goes down towards ac lines to the front (passenger side). Im pretty sure the longer ones are for the radiator fan motor. the shorter ones i have no idea plz help me out if ya know. one of the smaller ones is black/purple and the other one is just black. maybe one is a ground idk. any help will be much appreciated
Heres a closer look at the shorter ones...
Old Aug 24, 2009 | 10:58 AM
BigBadLou's Avatar
Car: '91 Z28 convertible
Engine: TPI
Axle/Gears: 3.27 posi disc
Re: tpi wiring help!!
Those are for the TWO radiator fans. One pair goes to one fan, the other pair goes to the other fan.
Hope this helps.
Lou
Old Aug 24, 2009 | 06:43 PM
Car: 91 Camaro RS
Hope this helps.
Lou
o ok thanx....i only had a single fan so thats y i didnt recognize the other ones. can i still only run a single fan or would it be better to find myself a dual fan setup? if i stay wit my single can i just leave those cut wires like that?
Old Aug 24, 2009 | 07:08 PM
BigBadLou's Avatar
Engine: TPI
For a 350 TPI engine, I would recommend upgrading to the dual-fan setup due to more heat buildup in the cooling system. If you don't drive like crazy, you might be fine with one fan but if you plan on "enjoying" your new 350, the dual-fan setup would be much better.
For now, you can leave the shorter wires disconnected, they are not gonna hurt anything. Make sure you connect the the primary fan wires to your single fan. Those would be the longer wires.
Hope this helps.
Lou
Old Aug 24, 2009 | 07:22 PM
BigBadLou's Avatar
Engine: TPI
*Duplicate post*
Caspar
Jun 19, 2016 11:19 PM
jbd1969
Aug 17, 2015 07:06 PM
1989formula5.7l
Aug 17, 2015 02:56 PM
stalkier
Aug 13, 2015 12:59 PM
Sanjay
Aug 12, 2015 03:41 PM
