feul pump?
Old Aug 25, 2009 | 02:33 PM
dirtybrd88's Avatar
Car: 88 t/a tpi ported polished bolt ons
Engine: lb9 got 406 on paymnt wow FI 406
Axle/Gears: 99 z28 342 in back
feul pump?
ok got electrical problem involving my feul no power back ther can i and would u just add in a hot switch in and just splice in the feul pump housing harness wher should my energy access point can i use hot wire off pump relay so that way relay kills the power to feul pump in case i forget to flip the switch off and i get kill switch all at the same time wat do u guys think????
Old Aug 25, 2009 | 10:00 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: feul pump?
Have you checked the relay? Checked the fuse tucked in the fenderwell by the battery? Checked the Oil Pressure Sending Unit? These are the places your fuel pump gets electricity from.
Where in NC are you? I'm in Raleigh/Cary.
Old Aug 26, 2009 | 08:25 PM
justtodd's Avatar
Car: 86 camaro iroc
Engine: 5.0 tpi
Re: feul pump?
if you figure it out let me know what you found im having simular problem thanks
Old Aug 27, 2009 | 10:22 AM
1Aauto's Avatar
Former Sponsor
Re: feul pump?
I'd hunt down the source of the problem and fix it the right way. Check the ignition switch too for the heck of it,not sure if it triggers the pump,maybe someone else will chime in that knows.
Hotrodboba400
Dec 10, 2019 07:07 PM
83 Crossfire TA
Jan 3, 2016 01:26 PM
Gunsbee
Sep 7, 2015 07:10 PM
MSgt Luttrell
Sep 5, 2015 11:28 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
