Battery Connections: Terminating locations
Old Aug 26, 2009 | 09:58 AM
RiV's Avatar
RiV
Everything works... I replaced my battery cables ect,and fixed all the shorts I had and eventually the problem with a drained battery. After my engine swap the negative cable was bolted to the engine by means of the exhaust header bolt. I'm worried that this spot is a bad location since there is so much heat produced there. I was seeing signs of heatsoak on my previoius starter so I replaced it. Never had a problem with that starter until the engine swap(figured it was just the new headers being so close to the starter) Now, before I put this new starter to too much use,I've had a heat shield installed but I'm afraid if the negative cable connection on the motor gets too hot it will raise the resistance in the connection and cause heatsoak like conditions and poor voltage levels for everything else. Maybe that was my problem all along.
Does anyone know the proper place to connect the negative cable to chassis or engine block properly for an 88 TA?
Old Aug 26, 2009 | 09:38 PM
groundrat's Avatar
Car: 91Z28
Transmission: WC T-5
Axle/Gears: 10 Bolt Posi, 3.08
Re: Battery Connections: Terminating locations
Use one of the bolts on the fuel pump block off plate.
Old Aug 27, 2009 | 12:48 AM
RiV's Avatar
RiV
Thanks I'll try that
Old Aug 27, 2009 | 05:03 AM
groundrat's Avatar
Car: 91Z28
Just make sure you use a wire brush or something to clean off all the paint and rust so you have a good solid ground.
Old Aug 27, 2009 | 10:06 AM
1Aauto's Avatar
Former Sponsor
X2 make sure the contact area is clean.
Hotrodboba400
Dec 10, 2019 07:07 PM
Johnoooooo
Sep 22, 2015 08:55 AM
Jlanz55
Sep 6, 2015 02:35 PM
Hotrodboba400
Sep 2, 2015 07:28 PM
tonys91rs
Sep 2, 2015 07:07 PM
