Vats Acting Funky
Old Aug 30, 2009 | 02:30 PM
slow_305's Avatar
Car: Chevy Camaro 305 TBI
Vats Acting Funky
I have a 1991 camaro with the 305 motor. i don't have any type of security system installed except for the vats. Rarely, when i go to start the car and turn the key nothing will happen and the security light will stay lit if i leave the key in the on position. If i wait like 10 min with out trying to start the car then go to start it, it will start like nothing was wrong. Why is it doing this and how come when i go to start the car all i need is the key to get it past the lock position then if i take the key out and go to start it, it will start sometimes...
Old Aug 30, 2009 | 04:26 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: Vats Acting Funky
there are a gazillion threads on vats in here - use
there are also tech articles:
https://www.thirdgen.org/vats_passkey_system
Sounds like your ignition cylinder is worn maybe causing the no need for key issue
Inside the cylinder, there is a spring-loaded contact on each side that contacts the sides of the pellet on the key - the springs wear out and thus contacts don't make contact with the pellet - you can bypass vats or replace cylinder. If you replace cylinder, take new dummy key AND old pellet key to ACE Hardware, and get a pellet key cut using the new dummy key for the cut, and using the resistor value from the old pellet key - they are @20 at ACE.
Old Aug 30, 2009 | 10:23 PM
slow_305's Avatar
i have searched for hours and i couldn't find anything similar problem that i have and i kinda don't wanna just by pass it.
thanks for the info though i already have gotten 2 different new keys and it still does this problem. your saying i need a new cylinder cause those springs are bad?
Fanatic1074
Oct 3, 2022 05:57 AM
RedLeader289
May 28, 2019 01:47 PM
RS Reaper
Oct 17, 2018 07:52 PM
Luigytico09
Oct 1, 2015 08:46 AM
ironbmt
Sep 27, 2015 06:00 AM
