Need help saving my kid money - '91 RS VATS Bypass
Old Aug 30, 2009 | 03:13 PM
wrcdbs's Avatar
I want to bypass my son's VATS in his 1991 RS so I can drive my truck again - how do I identify the VATS connector under the dash? If anyone has pictures it would help - there is a recent thread with pictures of purple and black wires on a '91 but there seems to be some question whether that is a correct installation.
Does 800 ohms seem like a correct value for the resistor? Also, does it make any difference how many watts the resistor should handle?
Would appreciate any pictures and specific help -
Thank you!
Old Aug 30, 2009 | 04:21 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: Need help saving my kid money - '91 RS VATS Bypass
That pic with the purple wires - see the two white wires in the orange cover - that's the VATS wires - plug the resistor in them (on the car side, not the steering wheel side).
The 16 possible resistance values are listed in the tech articles:
https://www.thirdgen.org/vats_passkey_system
Old Aug 30, 2009 | 09:10 PM
wrcdbs's Avatar
thanks - so should I go to 900 ohms on the resistor?
Old Aug 30, 2009 | 10:22 PM
wrcdbs's Avatar
appreciate the help . . .
Old Aug 30, 2009 | 10:53 PM
Car: 1992 RS
Engine: Carbed 350
double check the resistance of the pellet just to be sure - 800 is kinda in the middle
Old Sep 1, 2009 | 11:21 PM
Stephen's Avatar
Car: 87 GTA
The VATS controller is looking for 1 of 16 SPECIFIC resistance values, with only a little leeway in each of the possible 16. A 800 resistor is only gonna help you IF that happens to be the one that is correct for your car.
You'll hafta find out which one your key is, before guessing randomly. Unless you wanna go buy all 16 different values & start testing them one by one, until it starts.
Now, if your son has lost the keys, then you have 2 options.....
Buy the 16 different resistors & start testing
OR
Go to a GM dealership with the VIN & your title (to prove you own it) & get a new key. Or see if they'll tell you which resistor value is correct for your car & go buy that resistor.
Old Sep 10, 2009 | 08:31 PM
wrcdbs's Avatar
thanks -
have been out of town so haven't had a chance to get this done yet - will check the other key and resistance at the wires again.
Also, do I need to plug the wires back into the connector once the resistor is soldered in? Sorry to be dense, but I'm not an electrician . . .
Old Sep 10, 2009 | 08:34 PM
wrcdbs's Avatar
OR
Thank you - I'll double check resistance in both keys and in the wires. Have been traveling and unable to get this done. Also, do I need to reconnect the connector once the resistor is soldered in? I'm not an electrician . . .
Old Sep 10, 2009 | 09:11 PM
Stephen's Avatar
Car: 87 GTA
You won't be able to. The 2 pin ends of the resistor, will be inserted into the wire connector end, then shrink wrap/electrical tape it shut, to protect & key the resistor from falling out.
No resistance to check in the wires. Just the keep will give you the calue of the resistor you need to use.
Old Sep 12, 2009 | 02:44 PM
wrcdbs's Avatar
Thank you!
thanks to everyone who chimed in - car is up and running again -
Old Sep 12, 2009 | 02:53 PM
Stephen's Avatar
Car: 87 GTA
What did you end up doing, to get it running again?
Old Sep 12, 2009 | 04:21 PM
wrcdbs's Avatar
Exactly as suggested - unplugged the connectors, found a 390 ohm resistor (after confirming that the car had a 402 ohm "chip") at Radio Shack, bent the ends to fit tightly in the car side connector, tested to ensure she started several times over, then secured the resistor in the connector, taped the wires, and put it all back together. Very slick - no solder, and it's reversible should we ever want to restore the car to complete stock . . .
$750 L98
Feb 1, 2025 02:25 PM
ALIENhumanoid
Members Camaros
80
Apr 23, 2016 11:35 PM
92projectcamaro
Dec 8, 2015 12:25 AM
Bohemian
Aftermarket Product Review
Nov 25, 2015 09:38 PM
