wiring for dummies
Old Sep 9, 2009 | 09:29 AM
Hiccup's Avatar
wiring for dummies
I've just about finished putting together my 85 Z and have pretty much figured everything out. It's a TPI with an 87 roller cam engine and it runs with the exception of the temp guage and no charging voltage. Ihave discovered there is a missing wire from the post on the back of the alternator and I need to know where it goes. Starter? Battery? Both? Fusable link - how do I replace it? I bought the car with the engine completely disassembled and in boxes everything mixed together loose and it's the first FI project I've ever worked on. Pls help!
Old Sep 9, 2009 | 09:39 AM
I H8 WWD's Avatar
Car: 89' IROC-Z
Engine: LO3
Axle/Gears: 10-Bolt/2.73
Re: wiring for dummies
This post (red circle which has a screw with a small tab/post it screws into)?
If so mine was used as a ground. Ill take more pictures when I get home to show you.
Old Sep 9, 2009 | 02:45 PM
Hiccup's Avatar
I've got the two wire plug and the Haynes schematic that shows I think, the stud on the back of the alternator in a circuit with the starter and the battery but I suck at reading the schematic. Just how do the alternator battery and starter configure?
Glowsock
Jan 9, 2017 04:06 PM
Caspar
Jun 19, 2016 11:19 PM
ndndndnd
Carburetors
17
Sep 5, 2015 06:24 PM
Bryan F
Aug 27, 2015 07:28 AM
Bert87
Aug 23, 2015 03:50 PM
