someone help!! fuel pump issue
Old Sep 19, 2009 | 07:59 AM
montesscamaro's Avatar
Car: 84 monte carlo ss 85 camaro z28
Engine: 350/350vortec
Transmission: turbo 350/700r4
Axle/Gears: stock posi
heres the story i went from 2.8 fuel injected to carbed 350 and when i start it it runs for about 5 secs until the pump turns off then its done then i turn key off then on and wait for the pump to build pressure then it runs for 5 secs again..... also its putting out to much pressure for my quadraqet what is the solution???
Old Sep 19, 2009 | 09:28 AM
t-top havoc's Avatar
Car: '87 Camaro
Engine: '92 Carb'd 350
Axle/Gears: factory stock
Re: someone help!! fuel pump issue
Does the cam have a lobe for the fuel pump?Does the carb have a return line?Is the carb computer controlled?
IDK what pressure the old motor required but IIRC,most carbs use only about 5-7 pounds unless it's a hi-po motor or on alchy.
Mine uses a Holley carb & Holley blue elec pump w/regulator set @ 6 1/2 pounds.
I would think with too much pressure you would be flooding before not getting enough gas.Could be a pinched fuel line?..?
Old Sep 19, 2009 | 01:30 PM
8t2 z-chev's Avatar
Car: '82 z28
Engine: L83 5.7
Transmission: 700r4-1985
Axle/Gears: 3.42 posi
You will have to rig up a regulator and possibly a fuel
pump circuit in order to use the in-tank pump-when i
removed the crossfire injection from my car for
modification,i installed a q-jet in its place for use in the
meantime,q-jet would not handle the 15 or so psi the
C/F pump put out(pump for port injection puts out
about 50 psi),so just used a holley regulator. I left the
ecm hooked up when i had the temporary carb setup
on,so pump worked normally still(tach wire of ecm must
remain connected so ecm knows engine is running in
order for fuel pump to stay on with engine running)
CEL will be on but you can remove bulb if it is a
bother.
Glowsock
Jul 24, 2025 03:15 PM
Frozer!!!
Jan 19, 2024 04:55 PM
92camaroJoe
Jul 29, 2023 07:57 PM
Infested
May 22, 2018 11:56 PM
92camaroJoe
Aug 13, 2015 06:07 AM
