help on cooling fan
Old Sep 22, 2009 | 06:41 PM
muskrat51's Avatar
Car: 1991 camaro RS
Engine: 3.1 V 6 tpi
Transmission: auto 4spd
help on cooling fan
I have replaced engine coolant temp unit and gauge sending unit and the fan relay and the fan will not come on when she heats up. the fan comes on when the ac is turned on. any ideas???
Old Sep 22, 2009 | 07:20 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: help on cooling fan
fan switch - pass side head between #6 & #8 cylinder. remove the connector, and with key on, ground it - if fan comes on, then the switch is bad. watch eyes/face when replacing, coolant comes out there!
Old Sep 22, 2009 | 10:36 PM
BigBadLou's Avatar
Car: '91 Z28 convertible
Engine: TPI
Axle/Gears: 3.27 posi disc
Without knowing what engine you have, we cannot give you any answers (no matter how much we'd love to guess).
TBI/TPI? Year?
To save yourself trouble of repeating this information in every post, simply fill out your profile with your car's info.
Lou
Old Sep 23, 2009 | 07:03 AM
bcfipp's Avatar
It is my dads car. He has a 1991 camaro rs. It has the tpi v6. I believe it is the 3.1.
Old Sep 23, 2009 | 09:08 AM
BigBadLou's Avatar
Engine: TPI
Not sure if you are the original poster (two different user names) but the posts sounds like it. *shrug*
Anyway, on the V6 MPFI engines, there is no overheat switch in the passenger side head. The ECM is the only thing that controls the fan on this engine.
If the A/C turns the fan on, that means that the fan circuit functions correctly all the way from the ECM to the fan.
What temperature did you let it heat up to? The ECM is programmed to kick the fan on at 238 degrees Farenheit, if my memory serves me right. So yes, your dash gauge should be showing 240 for the fan to kick in. If it gets to 250 and still nothing, I'd check the actual engine temperature with an infra thermometer. At that point, I'd also ohm out the coolant temp sensors (both, for the ECM and for the dash gauge).
Let us know.
Lou
Old Sep 23, 2009 | 09:13 AM
muskrat51's Avatar
Car: 1991 camaro RS
Engine: 3.1 V 6 tpi
I replaced the coolant temp sensor under the nose of the throttlebody and the gauge sensor on the pass. side of block, and also the fan relay on the firewall.
Old Sep 23, 2009 | 09:15 AM
BigBadLou's Avatar
Engine: TPI
How hot did you let the engine get?
Lou
muskrat51's Avatar
Car: 1991 camaro RS
Engine: 3.1 V 6 tpi
I t seems the temp gauge goes all the way to the red zone. had it checked by a mechanic and said that the gauge was goo but sensor was bad
Old Sep 23, 2009 | 09:17 AM
muskrat51's Avatar
Car: 1991 camaro RS
Engine: 3.1 V 6 tpi
I just bought this car two months ago and can't get used to the high temps these thing run at
Old Sep 23, 2009 | 09:18 AM
BigBadLou's Avatar
Engine: TPI
Hmm, at this point, I'd put a laptop on the ECM and check that it reads the engine temperature correctly and sets the fan request as needed.
Is the engine harness hacked up in any way? Previous owners do stupid things with our cars.
Lou
Old Sep 23, 2009 | 09:48 AM
muskrat51's Avatar
Car: 1991 camaro RS
Engine: 3.1 V 6 tpi
no car was owned by a 48 yo women that was the original owner. that is the only thing that I can think might be wrong something in the wiring.
Linson
Oct 24, 2025 02:00 PM
sheachopper
Jul 31, 2019 11:27 AM
oil pan 4
Fabrication
Oct 6, 2015 11:56 AM
Fanatic1074
Oct 2, 2015 03:47 PM
timbuck
Convertibles
Sep 28, 2015 12:31 PM
