Rear Defroster Wiring
Old Sep 27, 2009 | 07:23 AM
smoothjazz's Avatar
Can anyone tell me where I can buy the replacement wires that run fom the rear hatch struts to my defrost grid? My rear defrost doesnt work due to the
wires that come from the struts up to the grid are totally missing.
Old Sep 27, 2009 | 05:39 PM
punkdude908's Avatar
Car: 1983 Pontiac Firebird
Engine: LG4 305ci 4bbl
Axle/Gears: 10-bolt open diff.
Re: Rear Defroster Wiring
i have the same problem on my Bird. the wires corroded away over the years. i think i'm just going to use 10 ga. wires with a quick connect to hook it up like stock. i don't think you need any special wiring, but don't quote me on that.
Old Sep 27, 2009 | 08:47 PM
ringo234's Avatar
Car: 89 IROC Z28
Engine: 357 TPI
Axle/Gears: 3.42 Posi
http://www.frostfighter.com/
http://www.carparts.com/Defrosters/G...=10618-2002923
http://www.frostfighter.com/prt2600.htm
Here are a few places to to fix or replace your rear window defroster.
Old Sep 27, 2009 | 09:13 PM
///DAN///'s Avatar
Car: 1984 camaro Z28
Engine: 355 SBC
Transmission: 700 r-4
Axle/Gears: Strange 3:73 posi
I just replaced them with I think 10 ga wire the one side is only a ground so you need like a 6 inch piece and the other you can just go down the wire till it's good and splice it in there and use angled connectors on the ends to limit stress on the wire. Good luck it's an easy fix.
Old Oct 27, 2009 | 07:29 PM
2LTCamaro's Avatar
bringing this back from the dead. The entire wire on the passneger side from the connector all the way up the glass and touching all the parts of the grid is gone. How do i fix that?
Old Oct 15, 2012 | 07:53 PM
motokid108's Avatar
Car: 88' IROC Z.
Engine: 305 TBI.
Transmission: T-5 5 Speed manual.
Axle/Gears: Stock 3.08's I suspect.
useful post
1992 Trans Am
May 10, 2023 07:19 PM
Jorlain
Aug 24, 2022 05:11 PM
crt454
Interior Parts Wanted
Jun 23, 2017 02:25 PM
AkDrifted
Aug 17, 2015 07:45 PM
3rdgenparts
Exterior Parts for Sale
Aug 8, 2015 11:48 AM
