? on exposed strands on power wire for ignition coil
Old Sep 30, 2009 | 11:00 PM
89rs1's Avatar
hey guys i just noticed, that there is a area on one of the plugs for the ignition coil, its the thicker pink wire, which i believe is the power wire for the ign. coil, there is a area on the wire where theres exposed strands of the wire
would these exposed strands cause there to be no power coming to the coil?
the car cranks all day but wont fire, is this the cause?
Old Oct 1, 2009 | 09:01 AM
NINÅ's Avatar
Engine: ► 400 KUBES ◄
Transmission: 765R4
Axle/Gears: EATON POSI 4.56
STRANDED
Exposed strands are not a problem per se but might be an indication of wire pullback from the connector.
Use a voltmeter to determine if the primary is receiving voltage.
Happy Racing!
If People Drove Any Slower They’d Be Going Backwards
Fog lights are not driving lights. They look doofy. Turn em off slow pokes.
How bout those nervous nellies too scared to drive without headlights on in the daytime or if there is a little rain!
Old Oct 1, 2009 | 05:40 PM
rybread11's Avatar
Car: 83 camaro berlinetta
Engine: 40 over 350
Transmission: 86 T5
Re: STRANDED
I agree, or the wires are broke there within the sheething. definently would wrap some tape around there, and eventually replace that wire. you can get a new one from summit or other places with the plug for the distributer on the end. then solder in on to the old wire before the bad spot.
Old Oct 1, 2009 | 05:50 PM
rybread11's Avatar
Engine: 40 over 350
Transmission: 86 T5
Re: STRANDED
Actually i think you mean at the bottom of the plug, yeah I'll bet alot of guys are like that.
BRoss99
Aug 10, 2025 05:08 PM
Caspar
Jun 19, 2016 11:19 PM
92camaroJoe
Aug 13, 2015 06:07 AM
92projectcamaro
Aug 6, 2015 01:20 PM
