NO REVERSE LIGHTs?
Old Oct 5, 2009 | 12:57 AM
csimpson1's Avatar
Car: 1984 Black Trans Am
Engine: 350 bored .030
Axle/Gears: Stock. Wanting up grade
NO REVERSE LIGHTs?
I realized about a week ago i didnt have reverse lights. cops where i live like to write tickets to light problems like that, one for tail light, one for license plate light. so i need to fix ASAP. im not sure how that wiring is done, so i dont even know where to begin to look. thanks
Old Oct 5, 2009 | 01:25 AM
tom86iroc's Avatar
Car: 1986 iroc
Engine: alum. head 350 supercharged
Transmission: 6speed
Axle/Gears: ford 9in 3.90 35 spline moser axles
Re: NO REVERSE LIGHTs?
see if the bulbs are bad or the fuse first is it a stick or atuo then you'll have to check the reverse light switch depends on what tranny u have on the location of it
Old Oct 5, 2009 | 08:36 AM
csimpson1's Avatar
Well, it is a Automatic (boo!) and the bulbs arent bad. I had to replace the brake light switch, so maybe it is the switch, but i dont know how, or even where it is. lol
Old Oct 5, 2009 | 09:08 AM
BigBadLou's Avatar
Car: '91 Z28 convertible
Engine: TPI
Axle/Gears: 3.27 posi disc
The switch for the reverse lights is in the center console, on the shifter assembly. You can remove the shifter plate to access it.
The switch has 6 wires, find the blue and gree thin pair, that's for your back-up lights.
The blue wire has 12V with key on. The green wire sends power to the bulbs in the back when the gear selector is moved to "R". Check the power on the wires with a test ligth or a multimeter.
http://www.austinthirdgen.org/mkport...kup_lights.jpg
Not sure about Indiana state specific safety inspection rules but back-up lights are usually considered a convenience feature, not a safety feature. You can check your local safety inspection rules and make sure whether back up lights are required.
Hope this helps.
Lou
GTAman
Jul 3, 2024 07:29 PM
GeneralIesrussi
Carburetors
Jun 20, 2024 07:21 PM
Hotrodboba400
Dec 10, 2019 07:07 PM
Jetmeck
Sep 4, 2015 12:29 AM
Hotrodboba400
Sep 2, 2015 07:28 PM
