Need help with 92 Firebird lights / door switches
Old Oct 8, 2009 | 08:40 PM
PlanoDragon's Avatar
Car: 1987 Firebird Formula
Engine: H305
I have a 92 Firebird. Last weekend the map and dome light started staying on even with the doors closed. I checked the door jamb switches and they look ok. Is there a relay that could have gone out? If so, where is it located? Any help is appreciated.
Old Oct 8, 2009 | 08:55 PM
camaronewbie's Avatar
Car: 1992 RS
Engine: Carbed 350
Axle/Gears: 3.42 posi
Re: Need help with 92 Firebird lights / door switches
The door jamb switches connect the negative for the lights - take a volt/ohm meter and see if the wire from them (behind the kick panel) is grounded with the door closed - maybe it's touching somewhere between the door and the light.
Old Oct 8, 2009 | 09:06 PM
Engine: H305
Thanks. I'll check it this weekend.
Old Oct 9, 2009 | 09:17 AM
Mike M's Avatar
Be sure and check the dimmer to see if it is dialed up all the way.
BRoss99
Aug 10, 2025 05:08 PM
1992 Trans Am
May 10, 2023 07:19 PM
BlackTopKing
Aug 19, 2015 12:13 PM
tnrednneck
Aug 13, 2015 08:57 AM
Omega
Aug 10, 2015 12:46 PM
