Hooking up cruise.
Old Oct 10, 2009 | 06:24 PM
consequence's Avatar
Hooking up cruise.
I have a 1983 camaro 5 spd in which I just installed electronic cruise from an 84 into. I just need to make sure I have everything to make it work. Car doesnt run yet.
I have:
An instrument panel with the yellow vss box in the back of it.
Cruise control harness from the 84 5 spd
Brake relief switch
Computer for the cruise located on pass side behind the dash
Servo unit
Vacuum "ball"
port that goes on top of the intake manifold
Only things I think I am missing are:
Cruise switch for the clutch, is it the same as the brake switch? I have 2 of those. I also have a switch which doesnt have a vacuum nipple on the back. Harness has a connector which I suspect is for the clutch because brake is already in.
VSS for the transmission, the original car never had cruise, just a t5. Do I need to install a VSS for the transmission or are they already built in? Its a cable type speedo.
Thx
Cole Curtis
Theoretical and Street Racing
Oct 3, 2015 12:26 AM
mcfastestZ28
Oct 1, 2015 11:23 AM
Derrick86
Oct 1, 2015 05:12 AM
Gordonr1973
Sep 29, 2015 11:59 AM
tattmann
Sep 27, 2015 05:20 PM
