Idk what else to do...
Old Oct 12, 2009 | 06:46 PM
Blk91Firebird's Avatar
Car: 91 Firebird, 89 Bird, 86 Bird
Engine: None, 5.7, 5.0 L.O.
Transmission: None, T5, Thm 350
Axle/Gears: 3.23, 02' 3.43 rear disc, ???
Ok so I finally got past my problem with coolant temp switches (gave autozone 5 tries before I gave up on them getting me one that worked) and the next day it seems that my alternator is going out, barely make it home before my battery gives out. I get the alternator tested and they say its good so I change the battery. Didnt change a thing. my car will run till the battery dies. tried 3 alternators and nothing seems to be making a difference. Any suggestion?
Old Oct 13, 2009 | 07:39 PM
84 1LE's Avatar
Car: 89RS vert
Engine: Erod
Transmission: 4L65e
Axle/Gears: BW, 3.27
Re: Idk what else to do...
What is the voltage reading while the eng is running?Also have you connected a volt meter to the batt with the engine running?
Sounds like a wire is disconected between the alt & batt.Im just guessing though.
Old Oct 16, 2009 | 05:21 PM
It was a stupid thing lol I ran my fan to a toggle switch wired off my power accessory fuse, and thats what it was. You have to run your fan to the fan fuse or you dont charge
TheExaminer
Sep 28, 2015 02:28 PM
92firebirdguy
Sep 10, 2015 10:33 PM
86iroczwv
Sep 3, 2015 06:21 PM
theurge
Aug 21, 2015 12:46 PM
1985chevydude
Aug 20, 2015 12:29 AM
