Wiring harness 83 trans am 4bbl carb
Old Oct 19, 2009 | 02:27 AM
fychelio's Avatar
Car: 1983 pontiac Trans am ws6
Axle/Gears: ????
i know its no the place but no one responded to my post in the other section. my harness shorted out and cought on fire. Im looking for a wiring harness from the fender clip to the engine components for my 1983 trans am carburated. If anyone has one that i can buy from you please contact me nperezfinance@gmail.com Thanks.
Old Oct 19, 2009 | 04:50 PM
RedRokkit's Avatar
Car: 1984 Trans Am, 1986 Fiero SE
Engine: 5.0 H.O., 2.8
Transmission: T5, M4 Muncie
Axle/Gears: 3.73 disc posi, CAVALIER AXLES!!
Re: Wiring harness 83 trans am 4bbl carb
First question, is it just the engine bay harness that you need? or do ypu need a complete pull from the headlights to taillights to fuse panel? secon these cars are 25ish years old I could get you one from the pick and pull, but it would not be for your specific year or motor, but you could adapt it for the electronics that you need ( dist, alt, guages, ect) but that would require some modifying of the harness, which as stated is 20+ years old ........or my recommendation is get a PAINLESS harness, tell them what you got and what you are running, and it will be a PERFECT fit ......And you dont have to worry about 20+ year old wires shorting out and catching fire........My $0.2.... Im glad it didnt go up in flames bro.....and I wouldnt want to chance it again.
Old Oct 21, 2009 | 12:26 AM
John in RI's Avatar
Car: 1984 Camaro Berlinetta
Transmission: T56 6-speed
Axle/Gears: 4.11 LS1 Rear End
Your Car shoudl have 3 harness in the engine bay,.
1 for Headlights
1 for Engine
1 for ECM
The Engine and Headlight harnesses appear to be 1 harness at first glance. They feed into the engine bay on the drivers side firewall at the C100 Body connector. The ECM harness will enter the engine bay from the passenger side thru the side of the engine bay.
The "best matching" Engine harness for your car will come from an 82-83 ThirdGen. The 84-86 Engine harnesses are also a real close match, but some splicing is required. ( Wiper motor was changed in 84.)
If your looking for an ECM harness than your engine and transmission type are important to follow and you should get a replacement harness from the same type of car. (It will matter if your car is an LG4 or an L69) 82-83 are prefered for the engine/tranny combo,.... 84 - 86 might be a bit different because ESC ( Electronic Spark Control ) and an electric fan was added to even the base LG4 engine's ECM functions.
crt454
Interior Parts Wanted
Jun 23, 2017 02:25 PM
TheJoeY88
Dec 31, 2016 07:30 PM
Reddeath210
Oct 6, 2015 08:20 AM
86IROC112
Aug 17, 2015 02:00 PM
Dquickshift
Aug 12, 2015 06:21 PM
